It isn't stating that the alert is specifically an East /West error. It is indicating that something isn't moving.
Something doesn't test right. Why didn't the motor momentarily move when the ASC1 outputted 36Vdc? Even if the sensor circuit is not functioning, the motor would momentarily energize. Was someone at the dish when the East or West key was pressed or is it assumed that the actuator didn't energize because you didn't see the dish moving?
There should be momentary 5Vdc between S1/S2 and also between 5Vdc/GND terminals when the East or West key is depressed and before the LCD alert appears.
Leave all wires actuator disconnected and power OFF the rear panel master switch for an hour or more. There may be a short in one of the wire bundles and the circuit needs to cool and reset.
Are you using a polarity servo motor? A short could also be in the servo or it is running against the mechanical stop when energized. The 5Vdc power for both circuits is from the same source.
When the ASC1 is repowered without wires connected to the dish, test the sensor and the servo terminals for momentary 5Vdc. If there is 5Vdc, then only connect the sensor S1/S2 and the motor M1/M2. Test for actuator movement without alert message.
If the actuator moves without error, then connect the polarity servo motor and check for servo rotation and actuator movement without error.
