110 Satellite
Greg R
6
Suwanee, Ga
quad lnb question
Does the quad LNB have built in switches? I'm trying to install 2nd dish and cannot get lock or any kind of signal. I have the skew and elevation angles the same as my #1 dish and cannot get lock on signal. :confused:
The quad combine signal 110 and 119 normally so no other switches are needed if thats the only signal you want. But if you hook up a second dish say for like 61.5 then you will need a switch to combine all three sat.
Greg R - it's considered VERY poor form to start new threads over and over for what is almost certainly the same problem.
Go back and edit/delete all your excesses (request moderator help if necessary).BCS did the deed. ;)
Meanwhile, you've probably misaligned the dish. The Search button is your friend. It will help you find the many threads that have addressed how to aim a Dish 500.
In your various threads, you're talking about Quads, Dish 500, and 2nd dish.
How about you pull into one thread exactly what you are trying to accomplish, and EVERY detail of the equipment you have.BCS did the deed. ;)
My 522 has never done this before
811 comments
