110/119 lnb ?
signalsnoop
i just purchased 2 pansat 2500 and a DP legacy dual LNB antenna w/ diseqc
my question is if there are only 2 feeds of the lnb's how do i get each signal on each box. does each lnb run sat 110/119 or are they seperate. also how do hook up my direct tv sat for 61.5 on the same receiver?
thanks
Well, since you use the following terms in the same sentence "DishPro, Legacy, Dual" and its either DishPro or Legacy, I'm assuming you have either a DishPro or Legacy Twin LNBF
Since the only LEGAL stuff you can get on Dish Network is the following
119-NASA, Remote Control Help, the audio only channels and the very sexy "You need a second dish to view this channel"
110-Couple of Barker channels, GolTV and the equally intreging "You have a Dish500"
61.5-International Promo channel (very compelling content there)
If you're trying to do what I think you're trying to do, that is not condoned here nor talked about.
Wonder what all these hacks will do when Dish changes its encryption system : ) There will be a lot of cheap receivers on e-bay!
I really moved...
Please help!
