1080p Reception
The Dark Knight HD PPV: 6,199,995,600 bytes, 2h32m03s equals 5.44Mbps. Like I was saying, Dish HD PPVs currently are about 1/3rd the bitrate of their 1080p VOD.
General
Complete name : D:\Movies\The DarkKnight.ts
Format : MPEG-TS
File size : 5.77 GiB
Duration : 2h 32mn
Overall bit rate : 5 437 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 2h 31mn
Bit rate : 4 837 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Standard : Component
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 2h 32mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Video delay : -1s 542ms
Source
Actually 1080P/24 and 1080P/30 ARE in the ATSC specs. Experimental broadcasts OTA have been done. All ATSC equipped sets INCLUDING Dish receivers can receive them. That does not say that all such tuners will send them on to the display in that mode. Several networks and cable channels have discussed actually using them.
Could you give a source for these test that you are referring to?
I would have to go back and search for when they were done, but at least one test was done in NY very early on by WCBS, and I did watch it. I do remember that articles about the tests showed that many of the early ATSC receivers had trouble with it, and these results were what lead most to not use it later.
However Wikipedia states that some NBC stations actually send out 1080P/24 with metadata on displaying it as 1080i (no citation is listed). [ame="http://en.wikipedia.org/wiki/1080p"]1080p - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:progressive_scan_hdtv.svg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/7/7f/Progressive_scan_hdtv.svg/220px-Progressive_scan_hdtv.svg.png"@@AMEPARAM@@commons/thumb/7/7f/Progressive_scan_hdtv.svg/220px-Progressive_scan_hdtv.svg.png[/ame]
1080P Now Working
I just came home and discovered 618 on my 722. Did the HDMI test and it now properly shows 1080P/24 (as well as all others) as supported. Started download of The Beast.
Denon AVR-2309CI
Samsung HL61A750
Denon AVR-2309CI
Samsung HL61A750
Just checked now, same good news. trying the download of ep7 i think it was. looks like 618 fixed it.
samsung 67a750
Dish Twitter gives good (advanced) info
New Dish 1100????
