can't create OTA recording when out of home using DA
marklyn
95
94
Austin, Tx
I'm out of town for the next 3 weeks and I'm trying to set an OTA recording of a tv series. Every time, on android or even using the DA website, it fails to create the timer and states as such.
If I try to create a timer for a non OTA channel, like any higher channel, it works right off the bat.
Is there some limitation to creating a timer for an OTA channel that doesn't work when you're out of the house?
I've tried this on my phone android DA version, chromecast DA, and using the DA website on my laptop.
Any ideas?
Any ideas?
Your locals must be streamed, and DA cannot let you do anything with them except watch live (and even then, pause, rewind etc can't be used).
Back in my 722/Sling Adapter days, you could do this. If it's now true for a Hopper, I am both shocked and appalled. I can't try it out here at work because DA is blocked.
Why can't we use trick play on OTA DA as we do on Hopper locally? I don't think ATSC 1 broadcasts can even be encrypted.
I am recording stuff daily on several of my OTA channels. I have at least 10-15 timers for various series and news casts that record either daily or weekly and as of now it is still working. I just can't seem to start or create a timer when I'm out of the house using DishAnywhere. I suspect if I were home it would work.
I even vpn'd into my home network and tried it (being on same network) and that didn't let me create any OTA timers either.
OK, I just tested it. I left my house and moved away from my wifi network. I was unable to set a timer on two different OTA channels via DA. I came back home and tried the same two channels while within my home wifi. Same issue. I was able to set timers to my Dish local channels via DA. So, it seems to be universal, DA will not set an OTA timer whether you are in house or away. Time to call Dish.
But, you're able to set a timer using the hopper directly, correct?
Thanks for testing this!
I could not set ANY OTA recording away from home. Or even see them in the guide. Then I remembered I had unplugged the OTA adapter.
Occasionally I don't see the listing names in the guide for OTA's but most of the time I do. I just figure it's an occasional glitch, but not recording OTA's out of home is 'difficult' to just ignore.
This is what I get when I try recording OTA on my phone on my Home LAN:
If I select a satellite channel then there's no problem creating the timer.
EchoStar/Dish raises doubts about 'ability to continue as a going concern'
Dish Network signal finding advice
