I would like to power my SWM dish with the 12v system in my RV. My question is: Is the 21/29v output to the dish DC or AC?
Looking at the circuit board I see it is DC. Plan to replace the step down board with a step up board to go from 12v to 29v.I would like to power my SWM dish with the 12v system in my RV. My question is: Is the 21/29v output to the dish DC or AC?
This is strongly discouraged. If you do choose to do it, you'll need to supply 29 volts DC at 1.4 amps to the dish through a coaxial cable. It would be up to you to frankenstein that all together in a way that worked cleanly and consistently. It seems like it would be much easier to just plug a standard power inserter into a wall outlet in the RV.
I will let you knowThe question is...does it work?
More than 21VDC is rarely required to power an SWM dish at dozens of feet.24v is only indicated if the power supply is less than 6 cable feet from the thing it's powering.
I have been using a 21V power inserter to power a SWM LNB through 100 feet of solid copper core coax for over a dozen years with no difficulty. The solid copper core coax and good compression connectors is very important.24v is only indicated if the power supply is less than 6 cable feet from the thing it's powering. Hard to achieve with a dish, easier with commercial equipment
So what do they recommend now? By the way, I've had the same power inserter ever since I got service in 2011 and I've never had any issues.DIRECTV stopped recommending the 21v inserter about 10 years ago because of the number of issues in the field.
The voltage drop on the coax depends on the current draw of the device you are powering. (Ohm's Law v=IR) For example , a SWM16 draws a lot more current than a SWM LNB. I don't know what kind of a load DirecTV is using for its 1V per 20', but a SWM LNB doesn't incur anywhere near that voltage drop. Here are some real world measurements. The length of my coax run to the SWM3-RB LNB measures out to about 200 feet. With one end shorted the other end measures a DC loop resistance of 36 Ohms. Powering the LNB with my HR54, I measure the output of the HR54 at 19.8 V, and the voltage at the LNB reads 17.4 V. The output of my SWM21 is a little higher, 20.1V output, 17.8 V at the LNB. That would indicate that the current draw in a steady state condition of the SWM LNB is (20.1-17.8)/36 or 64 mA. I do not have the proper test equipment to determine the current draw or voltage drop under transient switching conditions, but it works.Tom Speer, it's great that your setup works for you. DIRECTV stopped recommending the 21v inserter about 10 years ago because of the number of issues in the field.
The precise criterion here is that the LNB needs to get at least 16v on the line when the receiver expects 18v, in order to switch properly The expected voltage drop on RG6 is 1v per 20' (according to DIRECTV docs) which gives little room for error on a typical install with a PI-21. I'd be somewhat curious what the actual voltage you are getting at the LNB.
