Thanks!HD will be moved from 129 to 110 on 6/6/23.
I still see the HD channels on 129, transponder 18.They moved or not??
HD version is still not available @ 110/119.They moved or not??
5/24/2023The SD MGM+ channel on 292 is on 119. I don't know when that move took place.
I would check later today. I am looking at my logs, and the major changes I have observed occur on Wednesdays. Since I have been documenting the dates with all the changes, there were changes on 4/12, 4/19, 5/3, 5/10, 5/17, 5/24, and 5/31.HD version is still not available @ 110/119.
Josh. Without trying to get into Dish's internal process, might I guess that the slight uncertainty and delays of specific channel movements is based on the complexity of this massive channel shuffle and balancing the logistics of unforeseen competing requirements for such a huge upgrade?This was pushed out to 6/13 in the overnight window.
Correct, they try not to overwhelm the team making the changes and on this ticket alone there are over 100 services that need to be moved....that being said it was just pushed again to the 6/20 overnight. If I had to guess (which I shouldn't but I will anyway) there is a pretty major upgrade that needs to be made at one of the two major uplinks and they're probably working around that schedule as well. When it rains it pours!Josh. Without trying to get into Dish's internal process, might I guess that the slight uncertainty and delays of specific channel movements is based on the complexity of this massive channel shuffle and balancing the logistics of unforeseen competing requirements for such a huge upgrade?
I have been to the uplink and man I would hate to be the guy who has to wire all that stuff.Correct, they try not to overwhelm the team making the changes and on this ticket alone there are over 100 services that need to be moved....that being said it was just pushed again to the 6/20 overnight. If I had to guess (which I shouldn't but I will anyway) there is a pretty major upgrade that needs to be made at one of the two major uplinks and they're probably working around that schedule as well. When it rains it pours!
Can't wait to see the pic if you can find it!I have been to the uplink and man I would hate to be the guy who has to wire all that stuff.
I took a picture and have it somewhere of just some of the cabling. It's amazing it all works.![]()
i want to see pictures too.I have been to the uplink and man I would hate to be the guy who has to wire all that stuff.
And it happened overnight! Thank you for keeping us updated on this. It looks like 379, 380, 381, 382, and 386 were moved for sure. There may be others, but I will take a look at it later this afternoon.Correct, they try not to overwhelm the team making the changes and on this ticket alone there are over 100 services that need to be moved....that being said it was just pushed again to the 6/20 overnight. If I had to guess (which I shouldn't but I will anyway) there is a pretty major upgrade that needs to be made at one of the two major uplinks and they're probably working around that schedule as well. When it rains it pours!
Channel | Type | Network | Now | Was |
378 | HD | Indieplex | 119, TP 21 | 129, TP 28 |
379 | HD | Retroplex | 110, TP 13 | 129, TP 18 |
380 | HD | MGM+ | 110, TP 22 | 129, TP 18 |
381 | HD | MGM+ Hits | 110, TP 19 | 129, TP 18 |
382 | HD | MGM+ Marquee | 110, TP 22 | 129, TP 18 |
386 | HD | Sony | 110, TP 13 | 129, TP 18 |
