Free to a Good Home - LNBFs, Feed Mount and 12V Coax Switch
Titanium
AI6US
7,687
9,157
Meadow Vista, Northern California
More satellite items to gift to a new home. I would like to see them working in a hobbyist system, rather than age out and not be used.
You pay the USPS priority shipping cost and one or all of these items will be yours. Reply to this thread with the item or items that you will use and I will message you back through the forum and get your contact information. Will send an invoice for the USPS mailing cost. First come, first served.
1. GEOSATpro SL1PLL LNBF - Standard LO 10750 Linear Single output KU LNBF
2. GEOSATpro GSL1 Bullet LNBF - Standard LO 10750 Linear Single output KU LNBF
3. Factory Sample - Prime Focus Standard LO 10750 Linear Single Output KU Prime Focus LNBF
4. G-Star Dual LNBF DiSEqC 2.0 Switch - Universal LO 9750/10600 Linear Single Output Dual LNBF with adjustable skew and DiSEqC 2.0 internal switch
5. Titanium Satellite CK1S - Combo C and KU LNBF - C-band LO 5150 Single Linear / KU-band Standard LO 10750 Linear Single Output
6. Prime Focus 42mm Feed Clamp - Suitable for mounting a KU LNBF on a three support leg prime focus reflector
7. Tru Spec 12Vdc Coax switch - Old School!!!
I'll take the Titanium Satellite CK1S - Combo C and KU LNBF - C-band LO 5150 Single Linear / KU-band Standard LO 10750 Linear Single Output and the Tru Spec 12Vdc Coax switch please.
I can't find the specs on that monoblock anywhere. Is the separation 4 degrees? If so, I'll take it.
i'll take the
GEOSATpro GSL1 Bullet LNBF - Standard LO 10750 Linear Single output KU LNBF and a CK1S if possible. Thanks
Items Still Available:
I could sure use the GSP SL1PLL on my fixed 87W dish to replace my SL2 bullet (non-PLL). I have an SL1PLL on my 103W fixed dish and it works very well.
Sent from my SM-G950W using Tapatalk
Maybe you could answer a question for me - looking at your item #6, I could have used that to mount a Ku LNBF to a 6 foot dish I picked up that had originally been used for C-band. But at the time I didn't know where to get one that would have been shipped in a timely manner (less than six weeks), so I made something out of an old broken steel shovel. So basically there is a steel ring that attaches to the three mounts and a smaller hole inside that the LNB pokes through, and a couple of clamps that look very similar to what's shown on #6. But what I was never sure of is do the clamps go on the outside (away from the concave surface of the dish) or the inside (closer to the concave surface of the dish)? I put them on the outside, closer to the body of the LNB and further from the surface of the dish (hope that makes sense), but have always wondered if I did it right. It seems to work okay except in really pouring rain, which I had thought would not be a problem with a 6 foot dish.
ancient Might be six of one, half dozen of the other or not... use the mount in a way that it places the feedhorn opening of the prime focus type of feed and scalar at the correct Focal Length for the reflected signals to converge into the feedhorn throat.some feedhorns have a long throat, which allow it to be solid for and aft to optimize. If not, the FL adjustment would need to be made with support leg or mount ponts.
Sounds to me that either the LNBF is not in the sweet spot or using a offset rather than a prime focus LNBF and not correctly illuminating the reflector?
Please start a new thread if you wish to have a discussion on this feed issue.
Reactions: primestar31
i would like number 4 + 5, thank you
Suggestions for finding a used Ku dish
LNB Challenge with an OVAL shape Dish
