Can you tell I am not a native English speaking fella?
Actually, no I couldn't. My wife is Russian, and her excuse is usually not being a technie and has nothing to do with language.
I know many a born and bred American who have no idea what that 'barrel connector' is called. They call it a connecting thingamajig!Can you tell I am not a native English speaking fella?
We become creative when we don't/can't remember certain words!!
You will still need a cable from the homerun to the dual tuner adapter at the H3. You cannot diplex with the H3 system.Thanks Sam. The antenna coax comes behind drywall in homerun room. A tiny room under basement stairs. The big screen tv is far away. Unless I buy extension cable, I cannot plug it into tv's antenna port. Another reason is this: I want to be able to watch locals on 4 tvs. With ota adapter on Hopper 3, I can achieve that.
When I moved south (to KY) many ,many years ago, I would hear the word "whatchamacallit" from the locals quite often. It took me a while to figure it out what it meant.Are we talking about a dohickey?
I am little confused. The coax cable from antenna (that is not connected to anything currently) is dangling behind Hopper 3. All I need to do is attach that cable to dual tuner airtv adapter, then connect the adapter to one of the 3 usb hopper 3 ports. Then, rescan local channels with Hopper 3. All the cables from Hopper 3 to Joeys r hidden behind drywalls.You will still need a cable from the homerun to the dual tuner adapter at the H3. You cannot diplex with the H3 system.
That "should" work.I am little confused. The coax cable from antenna (that is not connected to anything currently) is dangling behind Hopper 3. All I need to do is attach that cable to dual tuner airtv adapter, then connect the adapter to one of the 3 usb hopper 3 ports.
Have you tried connecting the antenna cable to your TV and scanning to see what your antenna can pick up?I am little confused. The coax cable from antenna (that is not connected to anything currently) is dangling behind Hopper 3. All I need to do is attach that cable to dual tuner airtv adapter, then connect the adapter to one of the 3 usb hopper 3 ports. Then, rescan local channels with Hopper 3. All the cables from Hopper 3 to Joeys r hidden behind drywalls.
I realize I need to turn on Hopper to watch ota channels. If I decide to cancel my Dish service in the future, I can use a 4-way splitter (attached to antenna cable).
Highlighting it and selecting the Quote button, then returning to this thread and selecting the Insert Quotes button worked for me.The relevant post in that old thread was #111. This platform won't let me copy and paste that for some reason ("oops we ran into some problems").
If all of the possible stations are UHF, and if the antenna in question happens to be VHF-only, then the assumption may be correct.Your antenna is inadequate, especially in the attic. You have to have good strong signals since adapters don't perform as well as a straight connection to a TV usually. You need more than just enough for a picture, you want a healthy fade margin to assure all stations come in, all the time. All of your possible stations are UHF, there are better antennas that could fit in the attic may need a preamp also. Outdoors is far better, don't worry about weather they are designed to work out there. The assumption that the antenna will not receive HD is not correct there is no such thing as digital or HD antennas as others mentioned. What did you order? Here is a report for your town in your sig. RabbitEars.Info
