Yet all of the uplink stations for DISH and DIRECTV are on our side of the Equator and they work as always. How can that be?All you need is 4 locations south of the equator , equal spaced.
All you need is 4 locations south of the equator , equal spaced.Yet all of the uplink stations for DISH and DIRECTV are on our side of the Equator and they work as always. How can that be?
I wanted to share a youtube vid on (how to destroy a blue marble) by (QNFee) (Harsh language prevents this) (how to destroy a blue marble) by (QNFee) Using time tables! How the sun and moon does not work with the globe or flat earth.Eh? Even if there was a dome, that would have to be one powerful flashlight. How high up is this dome supposed to be above the earth? Where and how does the moon fit into this setup?
Use a flash light on a mirror you can shine a wide beam.
Uplink on a different channel to a southern base transmitter to distribute the channels.
A LEO satellite requires a sphere, not a disk, just as the high orbit satellites do.LEO (low earth orbit) and U2 type high flying aircraft sense the 1950 .
Gps has a map in the memory and your location is from cell towers the more towers the more accurate GPS is.
Bing video Balloons
But that's not how they're doing it. All of the uplink centers for DISH and DIRECTV are in North America and they're using big dishes to send the signals skyward. If you review the geometry on these dishes, they are designed to send a very narrow beam rather than a wide choke shotgun beam.All you need is 4 locations south of the equator , equal spaced.
Mobile or base Or internet connection Up link on a different channel to a southern base transmitter to distribute the channels.
GPS equipment doesn't use cell towers. Only devices with A-GPS (assisted GPS) use cell signals. A-GPS was designed primarily to give a quick reading where GPS may take a couple of minutes. That's why when you turn on your phone indoors, it may place you blocks or some portion of miles away.If the GPS cannot find a Cell tower in requires you to enter your location and destination. With internal map and compass it will track your progress.
If you use the Gleason Time Chart as a flat mapping reference, South represents the entire outer edge of the disc. Any direction you travel in will end up being South if you go all the way to the edge.Which direction is "south" on a flat disk with north at its center? How can there be an "equator" on a flat disk? Why would the seasons above and below the "equator" be reversed on a flat disk? Sorry, it just doesn't work...
Is there some time mark in the video where a specific conclusion is drawn? There's a lot of NASA clips and some screen shots from a forum but most of the commentary is unintelligible.I wanted to share a youtube vid on (how to destroy a blue marble) by (QNFee) (Harsh language prevents this) (how to destroy a blue marble) by (QNFee) Using time tables! How the sun and moon does not work with the globe or flat earth.
That would seem to say that there can then not be any directions like "southwest" or "southeast". Crossing Antarctica would require going from south to south, and I have no idea how one would fly over the south pole, something that friends of mine that were with the ANG's 109th Air Wing did often while flying resupply missions in support of Antarctica science endeavors. Funny that none of them have ever mentioned seeing that alleged "wall of ice" while they were there.If you use the Gleason Time Chart as a flat mapping reference, South represents the entire outer edge of the disc. Any direction you travel in will end up being South if you go all the way to the edge.
The entire military is probably party to the conspiracy so even if they did see the edge of the world, they wouldn't be allowed to speak of it.Funny that none of them have ever mentioned seeing that alleged "wall of ice" while they were there.![]()
Maybe while they were still active duty, although that's still doubtful since these were civilian scientific support missions. Even "Lose lips sink ships" never kept anything secret for very long...The entire military is probably party to the conspiracy so even if they did see the edge of the world, they wouldn't be allowed to speak of it.
Your RIGHT. Loose lips meet an unfortunate accidents.The entire military is probably party to the conspiracy so even if they did see the edge of the world, they wouldn't be allowed to speak of it.
Now that really is funny! Thanks for the laughs!Your RIGHT. Loose lips meet an unfortunate accidents.
9/11 The first and only steel framed building to collapse?
Building #7 Never hit with anything from the towers collapsed !
It would have taken at least a month to prep the building #7 for demolition?
NO ONE IS TALKING
