Yep, nice feature. The other HWS doesn't have this issue anymore.It's not a bug it's a feature. It gives you five minutes to go make coffee....![]()
If you got a computer plug it in to it, wipe it there then plug it back into the H3 the H3 should reformat it I think.Is there a way to force the EHD attached to my Hopper 3 to re-format? I have transferred the recordings from it that I want and don't want what's left. I want to see if this will fix the error from popping up on first Hopper start up in the mornings.
OK, thz.If you got a computer plug it in to it, wipe it there then plug it back into the H3 the H3 should reformat it I think.
Formatted the EHD on my laptop and then plugged her in the H3 and performed a Hopper format. Transferred a couple recordings back to the EHD. Everything is working good. Will see if the error pop up happens in the morning when I fire up the Hopper. That is the only time I get it is in the morning startup. Thanks again.If you got a computer plug it in to it, wipe it there then plug it back into the H3 the H3 should reformat it I think.
I have one western digital drive connected to my living room hopper with sling and two western digital drives connected to my family room hopper with sling and I do not get your error message. It sounds like your hopper with sling receivers stop recognizing the drives and then realize the drives are present.
I have noticed a couple of times that my family room hopper with sling will stop seeing one of the two drives. This has happened 4 or 5 times. When it happens I power down the drive and when it powers back up it is recognized.
Of coarse I never had any problems with the old interface. The problem started with the new interface.
Sent from my iPhone using SatelliteGuys mobile app
No telling. My other WD EHD is the same model and it still is purring along. I guess I can flip flop the EHDs and see if the problem follows the problem EHD. Will see what it does in the morning when I fire up the Hopper and go from there.I don't think that it is the hard drive. My family room hopper with sling has stopped recognizing one of the two attached drives 4 or 5 times. However, I noticed that the drive that is not recognized is not the same drive each time. I think that the USB drivers in the new software still have issues.
No error code this morning. Maybe reformatting the EHD did the trick. I wouldn't think so but, go figure. Time will tellFormatted the EHD on my laptop and then plugged her in the H3 and performed a Hopper format. Transferred a couple recordings back to the EHD. Everything is working good. Will see if the error pop up happens in the morning when I fire up the Hopper. That is the only time I get it is in the morning startup. Thanks again.
Well what did it do this morning?No error code this morning. Maybe reformatting the EHD did the trick. I wouldn't think so but, go figure. Time will tell
No error code again. Do you think the EHD reformatting did the trick?Well what did it do this morning?
I'm not 100% convinced but its looking good. I have noticed people off and on having EHD problems may have stumbled onto a fix for some of those problems they are having. Time will tell, until the next update anyway.No error code again. Do you think the EHD reformatting did the trick?
Yep, for sure. That WD EHD is pretty old. Probably going bad.I'm not 100% convinced but its looking good. I have noticed people off and on having EHD problems may have stumbled onto a fix for some of those problems they are having. Time will tell, until the next update anyway.![]()
