This is awesome!!! So even with no internet microHD users can always have the latest firmware..I'm sold on the microHD again.
yup its nice.
Are you saying that if LO 5150-10750 is selected for scanning, this little marvel will scan both "BANDS" by itself at the same time in sequence, so all the channels of the scanned satellite are staggered by their respective bands, and showed such as one channel is a KU band and the next channel might be a C band....If that is true, then this little box is a wonder.
I assume you need to have a 22k switch between the C & Ku side of the LNB
Correct. The 22khz switch is preprogrammed for C/KU combined LNBFs
5150 - 22khz / OFF
10750 - 22khz / ON
yes it would...otherwise your frequencies would be off and C-Band stuff would show as KU and vise versa
You have to go into Motor / Switch Setting Menu everytime before you go into TP list or it reverts back to 30W when satellite is still the same in the Motor / Switch Setting Menu.
Brian,
are you saying that i need to just select the bandstacked lnb settings and just hit scan?
thanks
Thanks,.... so the external 22khz switch port #1 goes to the Ku band side and it is turned/commanded ON, and port #2 goes to the C band side and it is turned/commanded OFF, right?.... Always learning by leaps and bounds.
kodaz said:post 4.
in order to use my bandstacked lnbs.
I dont need to modify the scan range? or still need to and do i use the bandstacked LO lnb setup? or standards?
thanks
The entire IF range is still targeted, but the actual scan is defined within the user selected parameters. Example: The user refines the search parameter of a standard LO Blind Scan by placing a Start Frequency of 11700 and Stop Frequency of 11800. The found TP(s) will be found, analyzed and logged within this range, but the scan will look at the entire 950 - 2150 IF range and quickly skip over and not analyze found TPs outside of the user defined or default range.
The percentage of scan that is displayed is based on the complete IF range not the user defined range.
what is the setting to make the default scan range 950-1450? I've loaded the new firmware and it still defaults to 950-2150 and I have to change the 2150 to 1450 every time. I am using an odd LNB LO of 10000 so I can drop the leading "1" to get my lband frequency... is that telling the microhd I have a full band LNB when I don't and thus making it default to 2150 for the upper end stop? Maybe we need a default scan range input field or define the LNB field so the receiver knows what an appropriate high end scan stop frequency should be in normal situations.
I am so glad now there is a confirmation step before deleting DVR files.![]()
yup and you can delete more than one file at a time
