gtal98 said:Actually, scratch that. I'm assuming it is currently setup with the wing dish fed into the input on the 1000.4 LNB. Nothing changes, just take two output lines from the LNB and install the Solo Node. No 44 switch needed.
Did I read the diagrams right? You will need 2 Sling adapters??
navychop said:Your concern for "up to code" is touching. I've had at least 4 installers visit at the two places I've lived with Dish, and none of them showed the slightest interest in grounding anything. I always run the coax for them, they always mount and aim the dishes and activate the receivers.
Gee, if I shift over to H/J, I wonder what the odds are that the installer will decide I need a grounding run?
I agree. It's pretty simple. I have 3 lines coming in from my 1000.4 now that will go in to the Duo node and then out to the Hoppers and Joeys.
No doghouses in my install. (And, I don't pay for anything upfront. Local vendors just don't do that around here.)If you buy the equip you can do whatever you want: but if I roll out on a tc and you have a tripod screwed to a dog house hardlined suspension over to the eve: you will pay for the rebuild. Upfront.
Sent from my fingers.
View attachment 74188View attachment 74189View attachment 74190
No probs. You and I both know it's a perfectly fine user install. I've never lost signal in this, or my previous 3, homes. Good signal strength, too. And, nothing has ever fallen off, either. (If 4 bolts in the base, plus 2 on the tie rods, can't hold it to the side of your house, there's something wrong with your house.)The noob means well, Gary. However he's not as familiar with people here who install and maintain their own equipment.
I use quality premade all the time. Have for years. Works fine. Of course, if I was installing for a living, I wouldn't. I'd be pulling from a box, and crimping, obviously.What's with the premade made coax? No way in hell I would use that for any of my equipment, not even to hook up a VCR.
GaryPen said:No doghouses in my install. (And, I don't pay for anything upfront. Local vendors just don't do that around here.)
<img src="http://www.satelliteguys.us/attachment.php?attachmentid=74188"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=74189"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=74190"/>
gtal98 said:Maybe no dog houses - but it would still fail an internal DNS Quality check on multiple fronts: Only 4 lag bolts in the footplate (this alone is enough to fail, you need 6), improper grounding (Al wire not approved, the shiny DPP44s are not approved GBs so GBs must be installed between dish and switch, the mast/footplate is not grounded, can't verify ground source from pic), non-approved cable connectors (the black/silver PPCs are fine, the pre-made cable ends are not), some picky QAS might hit you for no service loops and improper cable clips too, but most wouldn't since there are no drip issues. All-in-all I could have your install up to code in about 30 minutes though, it's not terrible (assuming the ground source is approved).
Tyralak said:The noob means well, Gary. However he's not as familiar with people here who install and maintain their own equipment.
Scott Greczkowski said:Folks...
Please remember that SatelliteGuys is a website for Consumers run by Consumers.For those installers who value your craft and wish to discuss your trade we have a special forum just for installers. Please feel free to use that forum to discuss install techniques and procedures.
SatelliteGuys is proud not only to have America's Largest Satellite Forum for Consumers, but also America's largest installers forum as well.
Thanks for getting this one back on topic guys!
UTMTech said:So you've had poor techs out? So what. That doesn't mean we all suck. For us it's a writeuo capable of getting us fired. Way to stereotype.
navychop said:I don't consider them poor techs. I just think grounding is maybe the first thing skipped. I'm not trying to insult anybody.
Quit following me from topic to topic posting arrogant and condescending BS. You're not contributing only starting an immature argument.
It shows a single-node coming directly from an LNB for a single-hooper/single-joey setup. But, I would need to continue using my DPP44 switch with that setup because I have a 1000+ setup for International channels.
So, can I just hook two outputs from the DPP44 to the single-node inputs?
I dedicate output 1 for the DPP44 PSU right now. I didn't wanna run two PSU's down a single diplexed line. (I also use one for the OTA preamp.)Yep. That would be the way to do it. Or 3 lines to a dual node, and you still have one left over if you end up being able to keep a ViP receiver.
