Can anyone tell me how I can get 7 satellite dishes to go to one reciever? what switches will I need and how to connect them, if it can be done. I am using Omegasat 5700. Right now I am getting 4 dishes with a 4x1 switch.
Auric said:Where's our friend crackt? He'd be perfect for this thread![]()
according to the specs on the Omegasat, it will do Diseqc 1.1
so a 8x1 switch would work if you wanted to go that route. I use to use a Digiwave switch and it worked great
Can you look in the menus and see if there is a Diseqc 1.1 option?
Most FTA receivers won't control an old Legacy SW21 switch. (2x1)
A few receivers will handle an 8x1 diseq, but then I can't recommend most of the 8x1 switches.
Though it has limitations (which are spelled out in the FAQ), the special 22khz switch and two 4x1 diseqc switches should work with any receiver.
That'll give you a total of eight inputs and one output for a single receiver.
seeing as you already have a 4x1 diseqc switch just get yourself another 4x1 diseqc switch and a 22khz switch....this will let you connect up to 8 lnbs to one receiver....get an ecoda or EMP 22khz switch because i know for sure these two pass diseqc commands and will work with this wiring configuration....i have tried it myself....
I've run an AROC 8X1 (uncommitted DiSEqC switch)/(DiSEqC 1.1) in front of many different switches and motors with no problems. Best of all it was cheap less than $15.
I don't recall the rule of thumb (kinda depends on the dish and its size), but getting two birds more than... maybe 10° apart, will be challenging.
It's always fun to experiment, so let us know how it works out.
Best results will be with both LNBFs off center, one to the east, one to the west.
edit:
If you need some encouragement, just ask.
I have a number of pictures & threads to point you to.
Many members have doen multiple LNBs, so they may chime in, too! :up
Yeah that is what i want to do.
I've spent a small fortune on 4 22khz
switches and one 4x1 switch plus shipping
I did not know about the 8x1 in time.
The 22k switch has to be an ecoda though as most 22k switches wont pass Diseqc commands
