did you tweak the dish to get the best signal on metv?
satellites have "wobble" so you may have good signal at one time and not another
Well, that's generally what I tried to do..
And here's the weird thing. I'm getting MeTV in like super duper awesomely perfect now!
The other night I messed with it then the sun came up and it started messing up.
So I would move the dish off a few inches then recall it back to the exact spot I programmed a few hours earlier when it was working perfectly.
It would get a little better for a few minutes then mess up again. So I played that game for a few hours and it seemed like I was going to have to go back out and mess with it again.
Then my dad came over. He was going to help me (more like DO while I watch) cut down the poles because they are waaaay taller than I had thought/expected/planned for.
He started out by drilling new holes in the 6' dish pole then he used a tool called a tap and put bolt threads in the holes. The bolts make the adapter he made stay locked in place.
He got that much done but before he could get the saw (he has a hand held pipe saw) out of the van, my mom called and he had to go home for something she had going on. Oh well. Not a big deal.
So dad will be back sometime this weekend, hopefully, to cut the poles down and bring the dish(es) down to a height where I can work on them without having to be way up on a ladder like I was.
Anyway, after dad left I went back inside and watched my daytime shows on local OTA channels (courtroom and talk shows) while I sat there and tried to use that channelmaster program to fix my coolsat. That was a great big FAIL. I spent hours on that and it just does not work.
I ended up putting a file on the coolsat called "CS_6000_fixed.NDF". After I messed it totally up I uploaded the factory default file to it, then I put an updated one that has a beeper on the manual scan screen. But the channels and satellites are all wrong on that one. So then I put the "fixed" file into it and that was better but still wrong.
I loaded the "fixed" file into channelmaster and edited the satellite names and left everything else alone. I exported that file then uploaded it into the coolsat. BINGO! Proper satellite names. The transponder & channels are still outdated but I can work around that. I figured out how to delete and add transponders within the coolsat itself. It's clumsy and unfriendly but it can be done.
I'm hoping to eventually have the coolsat 100% up to date with all the proper satellites, transponders and channels so that I can use it as a tool to help me fine tune my dishes and find new stuff like unlisted channels, of which I've already found a few. Nothing of any real interest mind you but they are unlisted on any site I've looked at.
Anyway, after spending all that time trying to get the coolsat updated I checked to see what I could find on it, I had to rescan everything because all that uploading wiped it clean, it forgot everything from before.
And when I scanned in 87 AMC 3, MeTV was coming in perfectly!
HUH?? How did that happen??
So I figured that meant all the other satellites would be hosed since this one was working good. I moved it over to 99 Galaxy 16 and WVXF was coming in perfectly too. DOUBLE HUH???
So I moved it back to 87 and still it was working great! So I went back and forth between the two satellites a few times just for fun and it worked perfectly every time!
TADA!!!!!! I'm still mystified as to what I did right or how this happened!
But I'm not complaining!
What I'm worried about though is when my dad cuts the pole down I'll have to go through all this all over again..
But for now I'm totally diggin it! I watch Hawaii 5.0 at 4pm which was sort of a nice change from Adam-12/Dragnet (seen em all many times).
I fell asleep during Hawaii 5.0 and when I woke up later I was pleased to see that all evening the pc had been picking it up all that time just perfect as can be. So I hit the rewind button and went back to the Honeymooners. Twilight Zone, Perry Mason, Untouchables, it's all there and I'm watching it all right now, delayed several hours, thanks to the pc. I love that it lets me rewind shows and then I can fast forward through commercials.
I watched my shows from earlier until 3 or 4 am when other good stuff comes on thisTV (WVXF)..
This is awesomely awesome! Who needs pay TV? All the stuff I like can be found up there. Yes, it's hard work to get it but it's well worth it!
Good thing I'm too hard headed to quit. I may admit defeat but even then I'm too hard headed to quit. I may take some time off to chill out but eventually my hard headed self will get back to it.
Well, I'm far from done though. I'll be having more fun in a few days when Dad cuts the pole down and then again when I get the BIG dish put up.
My neighbor should be getting back with me soon about cutting those limbs down. I saw he called my cell phone while I was asleep earlier (I have really messed up hours), when I got up it was way too late to call back. I reckon I'll see him in the morning, I'm sorta sleeping half days now, each day my bedtime shifts later by 30 minutes to an hour.
I think that in general, I'm getting a lot closer to having an actual, working system that I can depend upon. And like it or not, kicking and screaming, I'm getting an education in something I would have never in a million years believed I would ever mess with, satellite stuff.
Thanks guys! You all rock!
