If you have decent line of sight, you may consider doing a Temp Install at Ground Level.Back up the ladder I go
At least to get your True South Sat.
Got another question....
When I plumb the pole I run into a problem. I have it plumb left/right but front/back is giving me a problem.
I can plumb the front, but then the back says its a few degrees off plumb, If I plumb the back, the front is off a few degrees. If I level across the top of the pole both front and back are off by about 1-2 degrees.
What should I do here?
I am using a wall mount, A pole is not an option.
If you are not using USALS, how did you do this?Then told to motor to drive to 63w,
It's that adjustment that tells you the error in alignment.Some manual adjustment got it locked in..
I've got a FC-90 satellite, with a HH90 motor, could someone please tell me what will be the 'true southern" sat to point it at? My zip is 72462, PLEASE, PLEASE, PLEASE HELP....Thank you!![]()
Thank you Phlawound, but would you Please explain to me where that's at according to 110?Oh, by the way, I'm running a coolsat 5000, an a nfusion nova, and a soliars...
Good to hear!Today I finished up my adjustments and can now track from 71w-123w.
are you using diseqc or usals?
I don't thinks usals stores location, at least on my system. you have to enter new coordinates.
also for usals your long./lat. need to be entered as a reference.
