I'm not seeing my -01 channels. Are you??OTA channels are now showing up in the Guide.
Actually, let me correct that. I'm not seeing the -01 channels for the four locals I get in HD from Dish. I am seeing them for other locals though....I'm not seeing my -01 channels. Are you??
Do you get HD locals from Dish?? I do and those are the channels my -01's don't show up for.I just set mine up last night. I can see the OTA channels that correspond to locals provided by Dish (i.e., 003-00, provided by Dish is visible as are 003-01 and 003-02, both OTA).
I cannot see OTA channels that do not have a corresponding channel provided by Dish. (Since there is no 027-00 from Dish, I cannot see 027-01 OTA.)
Hmm, mine still aren't...I do and my -01s show up now on the grid. Didn't the other day though... must have taken my suggestion to heart.![]()
I just received L6.17 this morning, so I'll post back here if/when I notice any issues. I also did not notice any SlingGuide related issues with my 622 while on L6.16...I have a 622 running in dual mode with 6.17. Over the weekend I started having some issues with the receiver. It seems like after I use the SlingGuide to interface with my receiver, my receiver starts having some problems. If the receiver is in standby mode and a timer is set to go off (either set directly or via SlingGuide), when it is time for the timer to fire, the 622 gives me the 'Acquiring Satellite' screen with checks 1-5 and then tries to download guide information (which usually hangs up). After a hard or soft reset (I've tried both), everything seems to be fine, until I use the SlingGuide software. I am going to avoid using the SlingGuide for a few days just to see if I still have any problems, since this could also be a bug with 6.17 (I didn't have any problems with 6.16) or it could just be that my 622 is on its last legs. Anyone else having a similar problem?
If you don't get asked, your receiver probably has "Record Plus" enabled. When that's enabled, you don't get prompted for which tuner to use.They need to let us select which tuner to use when recording a show or creating a timer. I did send feedback about this, I hope they listen.
