Wasn't the 622 and 722 supposed to get a software update yesterday to fix the Seagate EHD problems and give us folders on the EHD also?
Where did you hear/read that the software update is going to fix the Seagate EHD issue? I've gotten so used to unplugging and plugging that thing in I don't know what I'd do if it just worked... And folders, hmmmm, folders![]()
YEAH! Now I can't wait for that to spool. Sweet.
BTW - was it mentioned whether the fix is to just keep the hard drive awake (periodic pings, for example) or finally be smart enough to wake it up properly when necessary? I certainly hope it's the latter...
Seagate EHDs like the FreeAgent that go to sleep can be adjusted by use of a Seagate utility to not ever go to sleep again. The drives are set to default to a sleep mode but can be changed. No Dish "fix" is needed.
Seagate bare drives matched up with another type of enclosure don't have this issue at all.
I'm really more interested in the folders option that is supposed to be in the same update.
Actually, a fix is needed b/c 1) I shouldn't have to hook up the drive to a computer just to get functionality 2) Seagate's software only runs on Windows (not my Mac) and 3) I don't want it to "not ever go to sleep again." I want it to go to sleep when it's not in use and wake up when I try to access it (which is the way I assume it works with every other EHD).
...I want it to go to sleep when it's not in use and wake up when I try to access it (which is the way I assume it works with every other EHD)...
Dish have an approved list of internal drives for practically all DVR ( exclude 721 and 921 ).The FreeAgent is a turnkey solution for desktop data storage, not a video archive/ video dvr drive.
Buy a bare seagate and you won't need the fix. I have three seagate drives all designed specifically for video and I don't have any trouble with any of them.
If Dish had an approved list, people would be screaming about how there are much cheaper drives that are the same or better than the list so why should they bother?
* A one-time External Hard Drive Activation Fee on your account
o This fee allows an external drive to be passed or shared among all supported receiver on the same account
thanks- could the EHD's be used interchangeably on each unit (722 and 211)?
