Hello Everyone.
I have been lurking for a bit, and now I've taken the plunge.
I am acquiring a free Primestar dish and LNB, and a used Fortec Star Lifetime Classic NA.
I've read about using a switch to combine the V and H LNB outputs into a single coax on the Primestar dish (assuming the LNB works).
I've pointed a number of D* and E* dishes over the years and I know how to use a basic satellite signal meter.
I'm hoping to get a chance to at least temporarily set it up this weekend. I plan to use this dish and receiver to get my feet wet in the Ku band. I'm particularly interested in AMC3 at 87W. I do understand that once I get a taste, a motor probably won't be far behind
I'm also acquiring 6 FREE C-Band receivers (I've been told that they work) for some future experimentation.
Ultimately, my goal is to acquire a Pansat 9200HD, or something similar, to get the PBS-HD national feed (and to be able to occasionally record it). I do get the local PBS station in HD OTA, for THREE whole hours every night
With that goal in mind, my primary question is to whether I should be concerned with the lack of 4:2:2 support on the current crop of HD receivers. It seems to be one of the sticking points with just about every discussion of the FTA HD receivers. I'd hate to drop $400+ onto an HD receiver, and then find that everything requires 4:2:2 support.
Any opinions as to how important this issue is to someone whose primary goal is to pull down PBS-HD?
Thanks,
Kevin
Thanks,
Kevin
