Fisrt of all let me say hello to all !!! It's looks like a great hobby to be into..
I'm Stuck , please help.......
I did tons or reading and though I had it in contorl , until I start in the install.
I have a viewsat 2000 extreme, stab HH90, with a fortec 90 cm with a invacom quad 4 lnb . I'm in Eugene OR 97402.
Ok so my first question of many is, I'm reading the rotor install guide had to type of setup USALS and Diseqc 1.2 mode. Which Should I use..??
SO that leads me to my next question , which way do I point the rotor and what elevation do I need to set it at.
I used the sat finder to get these setting.
Eugene, OR 97402
Latitude 44° 3.672'N Longitude 123° 9.330'W
But after reading the install book I'm more confused. here is what I did I set the rotor evevation to 44 latitude, is this right? not sure what to do with LAT?
Which SAT in closest to me , where do I set latitude on rotor and satallite and which way do I point it. USe USALS or Disequ 1.2 setup??????
Thank you for the help, I look forward in time to be able to help others..
Eugene, OR 97402
