the ftp site has 1166x2 sys date of may 10th and the 1167x2 date of may 20th
I loaded the may 20th
Arent those year 2012 ???
says may 20 2013
ftp upload date was may 31 2013
the only 2012 file there is the hyndaz from 12-26-2012
I didn't see any april firmware there (judging by the ftp upload dates) just the march 27,30 then may.
Has anyone tested this receiver on 4:2:2 feeds? I found a pirate forum where somebody was trying to claim that it worked fine on 4:2:2 for him, then when people started questioning him about it, he said that it worked on some 4:2:2 feeds but not others. Then the thread shifted to other subjects. I haven't seen any mention of 4:2:2 on any other sites.
how well does it record HD stuff ?
I noticed that also.it would make the micro much slower.Interesting test! I was just wondering, I saw you did a detailed blind scan on the microHD (which would have slowed it's normal blind scan speed) and I know that can often find a higher number of channels. On the X2, does it also offer a normal vs. accurate/detailed blind scan? If not, I'd love to see a normal blind scan on the microHD vs. the X2 to see how they compare just in terms of speed![]()
A better test would be to point both to a sat like SatMex8 with low symbol rates and run the micro with a regular blind scan against the X2.Time them and do a channel count. Then do a detailed scan on the micro and compare the time and channels found.
you will be shock to see the results. there are others here which doesnt will like to see the results!!![]()
don't remember if i posted this before but never bought a microHD the Only reason is the composite output. always had trouble with earphone jacks.all my fta boxes go thru old crt before they get the pass/approval to a HD set.The microHD ..
