Hello HDTV and OTA user experts,
I have a Philips HDTV (model 42PFL5332D/37) with a built-in tuner that i've been using with indoor rabbit ears to pick up OTA network channels.. I've been using it for a year now with no problems.
Then, this past thursday 9/4/08, an hour before the Giants/Redskins game the video on channel 4.1 (NBC WRC-1 Washington mrket) disappeared! Only blank screen but with full audio. Signal strength said it was fine.
Since then, i've had no video reception for this channel...only audio. All other channels and stations are working fine and normal as always EXCEPT the NBC 4.1 channel.
At 1st I thought it was the NBC station having technical issues...but i bought another LCD tv and plugged it up to the same antenna and in the same spot as the philips TV. I did this to verify that it wasn't the broadcast station that was the problem. Sure enough, i was able to pick up 4.1 channel video and audio fine on the new LCD, which I will have to return since i can't afford 2 tv's! . I used the same rabbit ears that i had been using with the Philips tv.
I've reset my Philips tv and reprogrammed the channels a dozen times already and still same issue...NBC 4.1 just won't show video!
do you know any fixes or suggestions?
Thanks!
Thanks!
