Worth it to get a DVD upconvert player?
If you get the Zenith, I don't believe the newer batches upconvert over component anymore. So if you planned on using the component outputs you need to make sure you get one w/ older firmware. (I forget when Zenith disabled that highly desirable feature - which they call a mistake. You can get that info on the AVS boards if you like. You may also be able to find info there on how to replace newer firmware with an earlier version.)
Also, if you have an extremely large screen you'll notice some cropping on the right side of the image, which can be bothersome if you have a projector with multiple sources. (If you adjust to compensate for the Zenith, your cable/satellite image may now be shifted too far to the right.)
Other than those two issues, PQ is outstanding.
Samsung HD-950 with dual DVI / HDMI output
"Costco had the player for $99.00... and I passed. What was I thinking !! uuuugh!!!"
That you are lucky the Samsung HD-950 has landed see specs here -
http://news.designtechnica.com/article6320.html
do a google on designtechnica article6320 as they will not allow me to post a link until min 5 post membership .... :mad:
P.S thanks boys after 10 posts was able to add URL link :)
Samsung SIR T-451 Issue
Toshiba's new DVD can store 12-hour high-definition video
