If you really want to use the side 2 function of a 922, there is a way, but alittle bit of a pain. Hook the 922 up to the side 2 home distribuion port just like any other duo tuner, and go into the setup and set the modulator to the channel you want side 2 tv to receive its signal (air 60 or cable 73). At this point it is in shared view mode mirroring the same picture as side 1. Now activate the slingbox on a computer or iphone/itouch. The side 2 modulator will now show what is being broadcast to the slingplayer. You are going to need another 32.0 remote sync it and flip the bottom tab from side 1 to side 2. As long as the sling is active then you can use the 32.0 side 2 remote just as a 722 would work. Not the easiest way but if you need side 2 to be a seperate picture in a pintch. If you cannot get your hands on another 32.0 remote, use the remote on what ever slingplayer app you are running to navigate and change channels.
