View attachment 83251Well I finally got around to putting up my Bulleye II the first thing I did was to take the button hook off of my Orbitron SX-10 and put a quad legs on it, next I installed the bulleye II. The first thing I notice is the instruction that come with the Bulleye II is WRONG, for the Ku they H and V backwards, next thing I found out if you use a high end LNB like Norsat 3220 or a Norsat 1106HAF for the KU side, there is NO difference in the signal if you just run 13v to the V side and 18 to the H side, I did it both ways to see if the signal was any different, when I was not using the high end LNB's, when I tired using it with a cheaper LNB there was a difference in the signal when using 13v to the V side compare to using 18v to the v side.
The bulleye II works GREAT I have no power inserted just straight from the AZBOX HD box and it switch from KU to C to H to V with no problem and I am able to get a much stronger signal then I had before.
