It is more than 5 years ago that I tried receiving TV from window antenna....
Recently I got curious if the antenna's elements need to be electrically connected?
I mean, metal-to metal contact, by squeezing with bolts or soldered.
After all, the frequency of signal is pretty high...
Therefore, I used thin, insulated wires, bought some time ago from hobby craft store,
10 pcs of Printed Circuit Board with one-sided copper foil, and medical glue tape,
of course, temporarily....
and, the antenna worked! I guess, the capacity between PCB foil and the insulated wires was enough to deliver signal.
For stronger stations, it worked with just 2 whiskers. Reversing the vertical wires on the top and bottom did not make any difference.
Pictures, (some-annotated) - follow
