All you really need to do is find the 101 and the 99 and 103 should fall into place ... dither if needed.
Most of these meters do not tell you which Sat it is hitting.
It will?This is the key!...Most meters just find a signal....That isn't much help when looking at the Clark belt....There are dozens that can be seen...Use your STB as it will tell you which satellite by name your aimed at.
I think I would try using the recvr meter first, before I would invest in a meter. Unless your setting it up quite often.
Works for me every time.....Sorry I get a picture and I know were its aimed....I can lock on other satellites and get great signal no picture.It will?
A STB doesn't tell you what satellite you are pointed at.Works for me every time.....Sorry I get a picture and I know were its aimed....I can lock on other satellites and get great signal no picture.
