This would be for use splitting the signal coming out of the output of the Diniova Boss Mix antenna. I'm going to help the neighbor who lives behind me cut the cord by tying him into my antenna. So you're saying this splitter would work since it's post-preamp correct?
Where the two "MATV" outputs are, can have additional splitters put inline off one (or both) of those THERE, and split to more tv sets.
Ok, thanks. That's exactly what I'm wanting to do.
If he lives in the other side of a duplex you share, than ignore this.
It's a 4-plex and he lives right behind me. There's a utility room that runs down the middle of our building where all the MDU stuff lives. So it's really easy for me to get in there and add him to my antenna.
Keep in mind the risks involved with connecting two separate homes together with coax that have separate panel grounds or even separate power transforners.
At a minimum NEC codes MUST be adhered to.
Since the coax will act as a bonding jumper between the entrance panels, huge differential voltages and currents could occur.
At a MINIMUM i would suggest using line "isolators" on both ends of the coax running between the buildingst to isolate both the shield and center conductors on both ends.
And install grounding blocks on both ends as well.
The arrows indicate the direction of flow of DC power from the power supply to the amplifier, not the direction of the TV signal flow..Next related question: this Rocketfish 3-way splitter shows power pass with the arrows pointing different ways (all pointing to the IN port, I'm assuming?)
So I could put the preamp in the utility room and the power supply inside the house with this type of switch, correct?
