This is probably a dumb question but I have an OTA UHF/VHF/FM antenna in the attic,am primarily using it to strengthen my FM signal reception on my stereo receiver. Come feb. the digital transition won't effect the fm radio signals will they?
if you use the RF cable I assume so because the TV is analogThe converter boxes being offered now. Are they just going to convert the digital signals down to analog?
yepIn other words, put simply, they are taking the new digital signal (better quality) and downgrading it back to analog for the sake of the tv set?
And will there be some tv stations that continue to send analog? The reason I ask is that , when they talk about the upcoming change, they say "most "signals won't continue to be received by your tv, implying that some chs. may still come in even without the new boxes.
Thanks!
Got ya, thanks for your explanation, just as I thought!
Can I ask you another related question? At least related to the feb.09 broadcast signal change. The converter boxes being offered now. Are they just going to convert the digital signals down to analog? In other words, put simply, they are taking the new digital signal (better quality) and downgrading it back to analog for the sake of the tv set? And will there be some tv stations that continue to send analog? The reason I ask is that , when they talk about the upcoming change, they say "most "signals won't continue to be received by your tv, implying that some chs. may still come in even without the new boxes.
Thanks!
