I think we will have to do this, we switched to Dish Latino max and the CSR said we needed 119 so we had a tech visit today. He said we did not need it, we have 61.5/72/77/110, so just activated and left, checking the channels before he left, but i guess he missed a few. We are missing many, but all are SD and we are getting their HD counterpart so not a problem since we have an all hd setup. The only one I really care about is IFC (missing WE, health, and AMC as well which have no HD channel), went on chat and he could not figure out how to make it show up, it just shows up green in the guide on 131 and we were getting it with AT250, the channels list for Max says it should be at 894. Checked the list for 119, and sure enough there it is. The tech chat i had said we did not need 119 and they will check the transponders for signal on Monday, but i am thinking we do need it, for some reason the package we have just won't let us access the 131 channel, the same goes for those other SD channels that we are missing. Again we were getting those channels fine before, so don't think its signal.
I am guessing we will need 119 just to get that one channel plus a few missing Latin music channels. So this is good info to tell the next tech since the last one said he was confused by the order to add 119 to an already 4 sat system. Now did you use the input on the 1000.4, i think thats what we have too, for 110/119, or just run it to the switch? Can you just plug in one of the lines into the 77 spot and the other into the additional spot on the 1000.4? I believe that is how it is setup now, when they set it up they ran a line from the 110 on the other side of the house to the 1000, and then a fourth line to the switch from the 1000. And can you just leave the 3 lnb on the 1000 or do you need a different one? I would like to keep the 1000 dish since i already have a dish heater installed on it.
Thanks for your help.
