All fta receivers are DVB-S and, at minimum, can decode standard mpeg audio and video. Then there is DVB-S HD. usually using H264 video. There is also DVB-S2. DVB-S and DVB-S2 may also use alternate audio stream types, AC3, DTS, Musicam etc. There is also the 4.2.2 video. Confused? yeah, I was totally confused. But now, only slightly. The best answer I can give to your question is: If your receiver is capable of the transmissions format, Yes. If only partially compatible, only the audio, or the video will be presented. If not at all compatible, nothing.
