checked lat and lon they are set right.Deleated all channels still OUT OF RANGE appears when trying to change satellites.Make sure you have your Latitude and Longitude entered correctly. (and not reversed - Lat for Long & Long for Lat)
not able to send pictures. i have checked all settings all ok have changed out every thing ck ok with fortec star checks out ok instaled receiver on friday saturday worked good. sunday would only stay on 83 which is my south sat will do one channel after a resetany sat movement from there will say OUT OF RANGE maby this will helpIs motor control USALS or DiSEqC 1.2?
Could you attach a photo of the install menu screen and the USALS menu?
all set USALSIs the motor mode set to USALS or DiSEqC 1.2 or a mix? Check the motor mode for each activated satellite that gives this error message.
