First of all…I want to say that I was never a tech for Dish Network, but I did work in cable.
I have seen several techs use perfect Vision rg6 and PPC EXXL connectors. First of all, Perfect Vision is made in China. The jacket is harder than Commscope’s and Times Fiber’s cable; I used a lot of both of those brands in cable. The techs also will put the non-flooded cable in the ground; something I would never do in cable.
The PPC EXXL connecters seem to be more difficult to install than many other connectors because the metal on the inside is longer than many others, even longer than their own EX. However, although I have seen 2 techs use cigarette lighters to heat the cable before installing the EXXL onto Perfect Vision cable so that the connector will go on all the way, everybody seems to say that both are excellent.
The PPC EX seems to be a connector than the EXXL. The PPC EX has less plastic, a longer nut, and the metal that goes down into the cable is shorter, making the install easier. I once read here that the PPC EXXL has an extra O-ring that the EX did not have…..Please, take your cutters and cut one of each type open, you will find that they are the same.
Also, one tech told me that the “Snap-N-Seals are frowned on by Dish Network.” Is this true or are those PPC’s just cheaper?
I also saw, for the first time, what I has heard from several techs…..Perfect Vision cable with a bad spot. I had heard, from a contractor who did both satellite and cable, that Perfect Vision would get bad spots, where the cable will look fine on the outside, but will not carry signal very well in one spot. I saw that happen with my own eyes yesterday on a DP installation.
I was just curious if anybody had the same opinion on which connectors are the easiest to push onto the cable; I know that it matters on which brand of cable you happen to be using, but, I remember that the PPC blue crimp connectors were always easier, for me, to push on than the compression ones. The Raychems were the best, but they are gone. I was just wondering if anyone has found one to be easier than others.
