I'm wondering why declination is also needed with H2H motors for offset dishes?
Declination changes with location, so it's necessary to have that adjustable.
Enb,
Realize that there are two different notions regarding DECLINATION.
One relates to your site's latitude and affects your dish elevation (but not your motor latitude setting). The further north or south you are from the equatorial plane, the more you must tilt the dish elevation to a lower angle to view the satellite. If you are directly on the equatorial plane, your dish is essentially pointing straight up at the satellite. This should be relatively simple to comprehend.
The other declination angle, which is a bit more illusive, deals with the magnetic lines which surround the earth and which you rely upon a magnetic compass to show you some depiction of north, south east or west direction. These magnetic lines are not laid out in a nice "square" grid like the latitude and longitude coordinates on the globe. They do not conform to straight line coordinates and vary considerably from location to location. Here the problem and the confusion arise because true north and magnetic north are not the same place. Not only this, but the magnetic pole moves over the years and the magnetic lines are not straight lines.
Therefore, they have come up with compensations for a magnetic compass, referred to as magnetic declination. If you know where you are and you know the magnetic declination at that location, you can "CORRECT" your compass so that you know where TRUE north is as opposed to magnetic north.
You might have to add 3, 7 or 12 degrees or subtract that much from it to obtain the true north direction.
Satellites are lined up according to TRUE north opposed to magnetic north, but the most common manner to locate the sat position is via a MAGNETIC compass, which does not always point to the TRUE NORTH.
Therefore, if the magnetic deviation is +5, +3, -6, -2, +12 or -7 degrees, you have to add or subtract that many degrees from what your magnetic compass shows in order to aim the dish in the proper direction.
Along the Mississippi River basin, this angle of declination is virtually zero degrees. This is considered or referred to as an ISOGONIC line. Meaning that the true north and the magnetic north "appear" to be at the same location on the globe.
To the east of this line, you must ADD the declination angle to the geographic position to obtain the magnetic reading on the compass.
Some online calculators will provide you with both the magnetic and the true geographic headings.
RADAR
