Which satellite?
mazjim
5
In this far southern location I was asked by a snowbird how to be sure they're aligned with the right Starchoice satellite? Perhaps I'm trying to overly simplify alignment and the answer to my question can't be just yes or no!
Basically I'm asking:
1) If a receiver is on chan 299
2) It's a quad lnb on an elliptical dish
3) key in 4128 and you get the green message "correct signal found"
4) satellite shows A4
Can one be certain you are correctly aligned on the F1R satellite?
As a side note, SC has done a "rehit" as the box had been unplugged for a couple of months. The trip counter did increment however there is no reception on any channel.
what receiver do you have?
Some boxes you can press options 6-0-5 right arrow to diagnostic C screen. IN the corner there will be a number that will say like +7.0 or -3.0 etc.....if you are on F1 that number should move.
reason I ask which reciever is some boxes this wont work..there is another sequence of numbers to get to that screen
If you are hitting 107, you will get video on 299
From what I understand, if you get 299 via 111, you will not get any video/audio. If you are getting 299 via 107, you will get audio/video from 299 (currently showing Christmas/Holidays fire log channel). Hope this helps. Further, like Iceberg says, you need to provide receiver information for menu info.
Thanks for the two replies. I appreciate you both taking time to give me some info.
It was a 207 receiver and the diag C screen was changing. The highest was +3.2. From what dish_dtv says it's still possible to be on the wrong satellite. I'll pass on that information.
Regards
+3.2 means it barely has a locked signal....dish needs to be repeaked more
+5.0 is minimum
+7.5 or higher is best :)
PC-based DRV with EPG
Auto Change Aspect Ratio on StarChoice
