Each type of TV has it's own advantages and disadvantages. Plasmas and DLPs will usually have deeper blacks. LCds don't handle extremely fast motion as well. LCDs will usually have less of a reflection problem than Plasmas and will work better in a brightly lit room. A lot really depends on room condition.
Dlps are still the best bang for the buck.
S~
I agree it is way to hard to just say one technology is best. First you will need to tell us about the conditions in your room. Do you have a lot of light? Is it going to be a dedicated dark theater room? Is it a TV for the sun room? If there is a lot of light, does it fall on the TV? How much money do you want to spend? How big a TV do you think you need. How big is the space?
Describing the situation helps narrow down the list pretty quick. You would not want a front projector in a sun room with limited wall space, but it could be the ideal solution in a dedicated dark home theater (well fairly controlled light).
How about SD feed vs. HD feed? I have a 50" Toshiba 50H82 CRT projection that has very nice HD but the SD picture ranges from Pretty good to just plain crap. My 42" Samsung HL-S4266W DLP has a better pic with SD feeds. I also have a 15" LCD in my office that looks really good in SD (almost looks HD a times). So would Iexpect the same good SD picture on a 50" LCD? Or does PQ improve as screen size diminishes? Just looking for opinions. Thanx!
How does everyone like the Mitsubishi WD-65835 ?
LCD Televisions, Flat Panel Televisions & DLP TV - Mitsubishi 1080p | MDEA - WD-65835
Sorry I meant Mitsubishi WD-65735
I have a 65831, few years old now. It has been very good. I like Mits. I should have the laser in hand shortly.
S~
