Well now using the CS 6000, that has blind scan, I can watch the NBC mux and it also locks in the KFTL channel at barely 62-64 but it does not log in the channel if I even scan it manually. The CS 8100 did not even lock the signal , not even if I set the PID manually. Both Gospel and NBC are at 69-70 Q on the CS 6000. Last night it was also clear skies and Gospel was at 62 , today on the CS 8100 is at 32 only.
I agree with Anole that we should have a better documented FAQ or Sticky in regards of actuator arms , their differences and suitabilities for differents type and sizes of BUD. This 36" HD arm is an over overkill for my particular aplication , that is a 6 footer tracking from 30W to 139W (I can only track from 55W to 135 due to trees and a rooftop) but even an 18" arm can reach those extreme sats). Althought the 18"arm at 30W will only have less than 2 inches inside therefore putting too much stress probably. the HV or higher count version better for Ku tracking since it has more precision to stop.
I still have to analize the VBOX further , but so far I am under the impression that the GBOX only add cosmetics improvements (pretty much like what Raul Castro has done so far in Cuba) like 6 caracter SAT names rather than positions or pulses only, or customizable names half of them (30 fixed + 30 customaizable). BTW It reminds me of my 9242 HD PVR from Bell TV , after I bought it , they came out with a newer model that is basically a stripped down version lacking some very important features. This is only speculation of course since I have not been able to test both side to side but the key is that the precision is within the actuator nor the controller. The controller could read double the counts (up and down of the pulse like Anole suggested) but the actuator has no way to stop at those places , it can only stop at the center of the pulse. In any given system the total accuracy or precision or efficiency is always determined by the lowest accurate part of the system. It is the equivalent of one meassuring the length of a 2x4 stud with an english tape that is only 1/4 of an inch accurate, you would be able to tell or assume that the length is 6' and 3/8 but because of the poor accuracy of the tape you can only cut the length at 6'and 1/2 " at best. In this case it means nothing to have a better "brain" read decoder if the cutter (read actuator) only has a 1/4" precise tape. I hope you guys see my point here.
All this "trova" is just to defuse the "internal rant" because it has taken me several months and I have been reading and posting questions about all this just to select the optimal mover system for this 6 footer yet I feel I was never given the proper answer. Our forum has a lot af valuable info in this matter , do not misinterpret me, but I feel that it is either scattered or difficult to find or I do not know what else but in any case I was under the impression that bigger was better and that the GBOX was the "God" and I do not think neither are the case. Pretty much like Castro I always end up blaming the americans for my mistakes , lol , classical cuban comunism , lol. From 135W (I know I can not get further because the rooftop so decided to start factory retracted just a bit west of 135) to 72W I have 490 counts or less than 11 inches wich is consistent to 48 counts per inch (I did not mark the start, grrr).
In any case instead of continuing blaming or ranting I will gather more info and try to somehow gather it all together and organize it to eventually end up with having a full conprehensive info on our forum, with everybodys input of course.
Time to start tracking with the birdog's spectrum analizer on Ku a see those peaks going up and down as the dish travels the arc.
Cheers
JJ the Small C Band Guy ........... small refers to the guy not the Dish , lol.
