Where do I start in my effort to upgrade my old Dish 500 system to Dish 1000?
CapoDi
The Colony, Texas
I have a Dish 500 system with a single coax running to my Echostar 2800 receiver to get premium stations. I also have an off-air antenna I use for local stations and cable to get access to the internet and 60 or so analog cable stations.
My plans are to purchase a HD monitor or television to replace my aging 15 year old 35" RCA console.
I have installed a number of C-Band, Direct TV and Dish 500 systems in the past. I am just really confused as to where to start.
I am hoping someone can give me some direction as to what all I would need with respect to hardware, switches, splitters and cabling in my effort to upgrade my system.
I am looking at the 811 receiver and the DISH 1000 dish, both of which are listed on ebay. I am really open as to where to purchase this equipment, ebay was my second stop. I got very little help from local retailers...
I would appreciate any direction someone might be able to give.
Thank you...
its really not a big deal. if youve pointed a dish before this ones no different. no switch is needed if you only want to add an 811. point it just like you would a dish500 and 129 should just be there...fine tune at your leisure. You will need to run a short jumper from the DP dual (the 129lnb) to the single port on the DP+ lnb, this combines everything for you. then a single line to your 811, check switch, selct alternate, run, done, cancel, yes....you shold be golden...oh yeh dont forget to ground it.
keep in mind this is all assumption as i havent done one but....
The above solution sounds attractive.
What sort of prices have you found for the 811 and for the Dish1000 ?
(looks like their 1000 price went down about $12 in the last few weeks)
Help with hopeful upgrade please.. this can't be right.
Help with simple upgrade
