what size dish any for satmex 5 @ 116
manuelpaz
198
usa
Hi all i just wonder what will be the right size dish to get ku signal for satmex 5 @ 116 for two channels from mexico. thank u for any comments. manny
C or KU?
If KU the answer is a big old KU dish....when you get as far north as you are (jersey/NY area) the dropoff for reception is immense. Here in MN I use a 48" minimum if I wanted those. The 6 footer with a KU LNB got a few stations on there.
30" or 36" no way
but what channels are you looking for? I guess you might want to make sure they are still up
yeah same here in Minnesota on C-Band
But for KU the footprint is really bad the further north you go
I get most with a 6ft Fortec.. except Guatevisión and few others that prob need a bigger dish or are not there any more
It all depends on where you're located, in southern california i get Ku with a small offset dish (less than 3ft) and a Q above 80 con Televisa Tijuana's channel and 60-70 Q on the religious channels, and on C with a 6ft i get 82-85 channels at C band.
Cheers
Mike
Satellite Question
Card Selection Help?
