Pepper, you're the Man!, I mean Mad Scientist!
Way earlier today, I was looking inside the slot for the key-switch and thought there was something to the back-right that was sliding (eye sight the 3rd thing to go
), part of the reason I did not comprehend everything you said.
However.... (For everyone else)
Removing the battery cover and then Blue 2 Key-Switch on the 6.3 remote,
There is a small grey piece in the center that will slide left to right when looking down at the remote keypad.
This switch moves side to side depending on the width of the 2 legs/prongs that are on the key-switch.
SW POSITION -- 622 DISPLAY ------REMARKS
...1st position is TV2 UHF PRO -------This is automatically selected when inserting the Blue 2 UHF PRO key-switch.
...2nd position is TV1 IR -------------This is automatically selected when inserting the Green 1 key-switch.
...3rd position is TV1 IR/UHF PRO ----This is automatically selected when inserting the Green 1 UHF PRO key-switch.
...4th position is TV1 IR--------------This is automatically selected when inserting the Black UHF key-switch.
..................................................NOTE: Not intended for use with the ViP 622, the 4th Position provides IR/UHF (non-PRO).
Ensuring UHF PRO remote for TV1 is programmed for "Address 1" and UHF PRO remote for TV2 is programmed for "Address 2"; I pushed the "System Info" button on the receiver; then one at a time, I hit the record button on the remotes. They took the new addresses, as well as TV1 shifted to IR/UHF PRO.
That is pretty neat to be able to point the remote (once keyed correctly) at the receiver while in System Info, and it will detect a Green 1 UHF PRO and change, instead of having to go into the Installation Menu and manually enable it (which isn't an option on the ViP 622).
NOTE: TV1 and TV2 can use the same Address on the remote, provided TV1 is IR and TV2 is UHF PRO. However, if both are UHF PRO, they MUST have a different Address, doesn't have to be 1 and 2, but must be different. Also, I did not play with the A/B switch to change frequencies, and don't know if they both need to be on the same freq or not.
Tomorrow I'll go by the retailer where I bought my extra 6.3 remotes and see if he has the Green 1 UHF PRO key-switches laying around.
Thanks again Pepper.
SW
