I'd consider it a test of the broken down bird placed there. Perhaps some day a better satellite will be placed there ... one that will reach Alaska and Hawaii.
Shifting satellites isn't a good thing. Imagine a globe. Place a camera above that globe, about 3x the diameter of the globe above the surface at the equator - center the image of CONUS (the continental US). Just for the fun of it, place the camera at 85º (about Chicago) and take your picture.
Now on that picture draw an outline of CONUS. Draw a small circle around Hawaii and another for Alaska, if your CONUS outline doesn't include Alaska.
Next move your camera to the same distance above the equator on your globe at a different position. For the fun of it, line it up with Colorado Springs, CO, and take another shot.
Take the outline you drew for the first picture and place it over the second. You can adjust left and right to get as much of CONUS in the picture. It probably won't be the same kind of outline that you would have drawn if you KNEW the camera (satellite) was going to have to work there.
The pictures above demonstrate AMC-2 moving to 105, and the reason why the footprint is bad for E*'s use.
Satellites designed for 110 and 119 are interchangeable as the 'picture' isn't as much different (and a wise designer would take a move into account). But move a satellite designed for 110-119 to the 157 slot ... the image is worse than the 20º move of AMC-2.
BTW: E*1 and E*2 at 148 were designed back when the eastern slots were not intended to cover Alaska and Hawaii ... which explains their lack of footprint in Hawaii. E*4 at 157 was never intended to be there. Hopefully E* can get more out of it than a placeholder.
Somewhere down the road there will be a "Dish500" pointed at 148-157 providing service ... but it won't be in Hawaii until the 148º birds are replaced.
JL
