What is Digicipher II ?
Flinthill
104
West Central Texas
I would like to understand what Digicipher II is. Does this mean the programming that has the DCII designation is in the clear or encrypted(subscription)?
Is the Motorola DSR922 the only receiver that can acquire the DCII designated signals?
DigiCipher 2, or simply DCII, is the name of the digital signal compression standard used on many communications satellite television and audio signals. The DCII standard was originally developed in 1997 by General Instrument, which is now the broadband division of Motorola.
he original attempt for a North American digital signal encryption and compression standard was DigiCipher 1, which was used most notably in the now-defunct PrimeStar medium-power DBS system during the early 1990s. The DCII standard predates DVB-based digital television compression and therefore is incompatible with the DVB standard. World map showing location of North America A satellite composite image of North America North America is the third largest continent in area and in population after Eurasia and Africa. ... Direct broadcast satellite, or DBS, is a relatively recent development in the world of television distribution. ... Events and trends The 1990s are generally classified as having moved slightly away from the more conservative 1980s, but keeping the same mind-set. ... DVB, short for Digital Video Broadcasting, is a suite of internationally accepted, open standards for digital television maintained by the DVB Project, an industry consortium with more than 300 members, and published by a Joint Technical Committee (JTC) of European Telecommunications Standards Institute (ETSI), European Committee for Electrotechnical Standardization (CENELEC...
The primary difference between DigiCipher 2 and DVB lies in how each standard handles SI, or System Information. DigiCipher 2 also relies on the fact that its signals must be understood in terms of a virtual channel number in addition to the DCII signal's downlink frequency, whereas DVB signals have no virtual channel number.
Approximately 70% of newer first-generation digital cable networks in North America use the 4DTV/DigiCipher 2 format. The use of DCII is most prevalent in North American digital cable television set-top boxes. DCII is also used on Motorola's 4DTV digital satellite receiver and StarChoice's DBS receiver (StarChoice is based in Canada).
? ? If you look at Lyngsat and find DCII channels, the "in the clear" are with yellow background. The rest are either available by suscription or to cable companies only. Hope this helps ya. :yes
Well, I think I understand a little better. :>) So much behind the scenes that makes possible the programming we tend to take for granted. Thanks so much for making the effort to pass this information along.
NextWave NCC500
Should I be able to get SBS 6 (74w)?
