What Antenna would I need
steve617
94
Hello I live in the North East TN and did a seach on Check HD. I am new to OTA HD Antennas. Are there anything that you recommend. Thanks
Steve
Yellow - UHF 5.1, 5.2 WCYB-DT NBC BRISTOL 93° 12.7 28
Yellow - UHF 11.1 WJHL-DT CBS JOHNSON CITY 99° 11.1 58
Yellow - UHF 19.1, 19.2, 19.3 WKPT-DT ABC KINGSPORT 99° 11.1 27
Yellow - UHF 39.1, 39.1 WEMT-DT FOX GREENEVILLE 222° 35.7 38
Steve
From www.starkelecronic.com 3017 94" long $48.55. Note that all the stations listed are on UHF, so a 4228 would work, but WCYB is reverting to channel 5 and WJHL will go back to channel 11 on February 17, 2009 so the 3017 works on VHF and UHF.
Because WEMT is in a different direction, you'll need a rotator.
If they revert back to VHF, that wont be good for me.. but i'm in the tri-city market area as well. I'm further north in VA. I have a DB8 with a PA16 pre amp on a rotator and can pick up wcyb, wjhl, and wkpt at 47 miles and WEMT at 67 miles consistently. I can also get WBXX out of knoxville at 115 miles most of the time. This is all over very mountainous terrain. Antennaweb.org says i shouldnt get anything but a PBS, so I am extrememly pleased with the DB8 for now.
Remember guys, Antennaweb is very conservative! Antenna selection is hit or miss in some cases. Save your reciepts! Its basicly a process of elemination in some areas. The info you get from this form will in most cases get you in the right "direction"--Ray
xium antenna "dish looking"
Indoor or Outdoor Antenna for these Channels?
