What am I doing wrong?
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,234
27,884
Newington, CT
I have been outside working on my C Band dish all morning. I now have it scanning the entire arc (Well I tested it from 87 to 131) and I am doing good, lots of transponders over the are over 80 (some even as high as 95) for a signal!
But I am having one issue. While I am locking in GREAT on one polarity I am getting ZIPPO on the opposite polarity.
The LNB is a DMSI BSC621-2 C/KU Band LNB. (No I haven't tried tinkering with the KU side.)
The BOX where the switch is when pointed at 11 o clock I get all the vertical and with the box aimed at 1 o clock I get all horizontal.
There are no markings on the LNB at all.
I get great signals with the LNB almost all the way out of the holder, and the same results with it pushed in about half way.
So what am I doing wrong?
i would start by measuring the voltage at the end of the cable where your lnb is....measure it on a H tp and then measure it on a V tp....that way you can determine if the receiver is sending the correct voltage to change the polarity.....
I think I may have figured it out... The satellite meter is not sending out different voltage for each polarity...
Dont think this meter was setup to handle a LNB like this...
I swapped the LNB out with a BSC621 and got signals. (Not as good as the 621-2...) But the meter supports the BSC621... but apparently not the 621-2.
So I will grab my haier TV and my receiver and head out side.
I was probably locked on both all along. :D
BTW just for grins and giggles I gave the KU a shot and am also getting good signals on the KU side of things. :D
"Wild Feed" Idiot !!
New Pentagon Channel mux INCLUDING HD on 101w Ku
