Update: I installed the 30" myself!
Ok, I decided to go up on the roof, as I did before with the 18" dish and use the recievers beeping signal page! It seemed very hard to get a signal with this thing compared to the 18". the way the installer had mounted the pole there was no way to get the dish pointed low enough to aquire a signal. So I had to turn it around side ways, so the dish could point lower. When I finally started to point it low enough I got signal! When I got it peaked, (hearing the beeping get faster, and then steady at a fast pace) I tightened up all the bolts, and checked the signal. My quality went up only 2 points to 98, but the power went up from 76 to 87. What exactly helps with the rain fade now? Is it just the size of the dish that helps hold the signal you currently have, or does it have something to do with a better quality, and power level?
