Weak Eastern Arc Signal Strength
you most likely sighted in on the wrong lnb
which box in the checkswitch screen does it show 72.7? it should be in the center ones
I used Port 2 to site the dish as it says in the instructions. I used my receiver to power the meter and LNB. I had the receiver set on 72.7.
I am now hooked up to Port 1 on the LNB.
The box in the "Check Switch" summery is on the 1st box where 61.5 should be.
Well I guess I used port 1 to peak 72.7. I went back and made sure y feedlines at the lnbs were properly hooked up. I had marked them at both ends when I re-made the short cables coming out of the lnbs. This time I double checked that I was hooked up to port 2 for 72.7 and got a better peak on it than before.
I did the "Switch Check" again and had the 3 satellites in the matrix. I went to "point Dish" and I now see all satellites. 61.5 is a little lower than I would like but 72.7 and 77.0 are now up to 58 on each.
Thanks to all for all the help.
HELP! Dish VIP722 Backfeed Setup
