Turd Fergeson SatelliteGuys Guru Original poster Jun 16, 2004 124 0 River Falls, Al Jun 18, 2006 #1 Will a W-Adaptor fit on a metal 105 superdish?
webbydude SatelliteGuys Master Feb 6, 2005 5,339 1 Akron, Ohio, United States Jun 18, 2006 #2 If you're talking about the w-adapter from the D1000, then no. The SD arm is too big
Turd Fergeson SatelliteGuys Guru Original poster Jun 16, 2004 124 0 River Falls, Al Jun 18, 2006 #3 I was wanting to make a "super 1000" and make it clean. But I guess I will have to look in another direction.
Mike500 SatelliteGuys Pro Sep 7, 2003 1,338 0 Thiepval Jun 18, 2006 #4 Turd, You can always make a correct sized support arm out of 1x2x 1/8 inch wall aluminum tubing, using spacers on the arm's mount.
Pepper DVR Addict~Mad Scientist Supporting Founder Mar 16, 2004 8,403 1,384 Satsuma, AL Jun 19, 2006 #5 Even if the bracket were the right size to fit, the LNBFs would be spaced too close together. The spacing on the Superdish is much wider than the 500 or 1000.
