Sean Mota said:That's a good one Ilya. I don't know. I have to look more carefully. You maybe right. I'll let you know...
Yes. That was the case...
I think the manual call-back feature is there for maintenance and trouble shooting purposes only. Don't worry about it. VOOM will use automatic call-back instead. They will send a request to your box via satellite and your box will phone home without your intervention. Currently they are not doing that. But they will in the near future. That's why you need a phone line. In addition, the phone line might be used for PPV orders.kirkdj said:Is the report back feature still disabled for everyone? Not really sure what this was for anyway.....just know it no longer works.......I was told by installer that this was for PPV.........is that true?![]()
In the case I described above, simply pressing VOOM button followed by WATCH clears the stuck pixels.Walter L. said:I've seen the "sticky" pixels a couples of times (even before the upgrade). The esiest way to get rid of them is to simply turn off the box and turn it back on (no hard reset is needed).
I didn't have a single lockup since the last software push. Even though, I tried hard!Walter L. said:I experienced two lockups during the weekend. On both cases it happened while changing channels. Has somebody seen this problem with the new software?
Yes, this problem is not fixed in the latest version, and was present in the previous version too. When you change channels, from time to time you may encounter one of three things: (1) picture with no sound (most often); (2) sound with no picture; or, (3) nothing at all (some times with the "No signal" message). In either case, the problem usually goes away after you press CH up/down once or twice.kirkdj said:Is it still a known bug about not getting sound after changing channels.....I have to change to another channel, then back to get the sound to come in. Doesn't do it everytime, but enough that it is annoying?
I have the latest update too....![]()
