T teknic Member Original poster May 19, 2004 11 0 PHX, AZ May 24, 2004 #1 just got connected, switching from cable to voom, cable works great but when viewing the hd channels it shakes anyone else have a toshiba 30HF83 with this issue?
squicken Member Supporting Founder Mar 24, 2004 1,046 0 May 24, 2004 #2 I have your TV. Picture is fine here. What do you mean by "shaking"?
T teknic Member Original poster May 19, 2004 11 0 PHX, AZ May 24, 2004 #3 the picture shakes, are you using the dvi cable provided?
squicken Member Supporting Founder Mar 24, 2004 1,046 0 May 24, 2004 #4 First, make sure the STB is set to 1080i (top orange light flashes). Native mode and the TV don't work. If that doesn't work, reboot (hold down power button for 10 seconds). If still a problem, switch to component or DVI to see if it's the STB or your TV. Just make sure it's not a problem with your connection. After that, call Voom. Good luck, keep posting if you run into problems.
