[VOOM] Antenna question
N
nostrodumb_ass
Guest
Currently, I have an 25 db gain antenna "distribution amplifier"
monted in my basement to compensate for a long cable run. To my
knowledge, I do not have a "preamplifier" mounted on my outdoor
antenna. (Voom installed, 10' boom Channel Master yagi style.)
Our local ABC, FOX and NBC stations are on and off reception (mostly
off).
Would one of these mast or antenna mounted preamplifiers help pull
in these signals?
Thanks.
-k
I've used this antenna amplifier with pretty good results:
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=15-2507
Cheers,
Dave
> off).
> in these signals?
> Thanks.
> -k
> *Yahoo! Groups Links*
> * To visit your group on the web, go to:
> http://groups.yahoo.com/group/VOOM/
> * To unsubscribe from this group, send an email to:
> VOOM-unsubscribe@yahoogroups.com
> <mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
I would run, not walk and get a Channel Master or Winegard Mast amp LIke an
AP8275 appropriate to the type of antenna and antenna hookups you have and
install it as close to the antenna as you can but leave enough wire for a
drip loop. Unless you are going over 100' I would get rid of the
distribution amplifier first and then add it only if you really need it
because it could hamper digital reception by amplifying noise as well as
signal.
Do not use Radio Shack product for this. It is just not at the same level
of performance. A rotor is important too if your signals come from
multidirections.
----- Original Message -----
To: <VOOM@yahoogroups.com>
Sent: Tuesday, January 18, 2005 11:37 AM
Subject: [VOOM] Antenna question
> off).
> in these signals?
> Thanks.
> -k
> Yahoo! Groups Links
[VOOM] Re: Antenna question
Don't the mast amps and rotors need their own power sources? Now I
need to run power 25 feet up to my antenna?
-k
amp LIke an
have and
wire for a
need it
well as
> signal.
same level
from
> multidirections.
> From: "nostrodumb_ass" <kkledzik1@y...>
(mostly
> > off).
pull
> > in these signals?
> > Thanks.
> > -k
> > Yahoo! Groups Links
Re: [VOOM] Re: Antenna question
Yes, but not exactly as you may think.
The mast amp power comes up to the mast amp via coaxial cable from a power
supply located inside the house. By the same token the amplified signal
from the mast amp outside comes down that same coax to the power supply unit
and is fed from there to the TV or STB.
The rotor is powered by a 3 conductor color coded cable to the rotor at the
antenna mast. The voltage is a pulsed type voltage around 30 volts. The
conductors are relatively thin. I have about 500' of this cable Channel
Master brand so if you need some I can probably supply it to you cheaply
because I can't use it all.
It's really pretty simple. Google Winegard and Channel Master sites for
better insight.
Sent: Tuesday, January 18, 2005 2:07 PM
Subject: [VOOM] Re: Antenna question
> -k
> amp LIke an
> have and
> wire for a
> need it
> well as
>> signal.
> same level
> from
>> multidirections.
> (mostly
>> > off).
> pull
>> > in these signals?
>> > Thanks.
>> > -k
>> > Yahoo! Groups Links
> Yahoo! Groups Links
J
[VOOM] oh boy !
M
[VOOM] Remote direct to OTA channels
